Keith Sparks A-10 Warthog buildup
LA
Richard Guidroz, a friend of mine is building a Keith Sparks design A-10. I will be posting pictures of the build up. stay tuned.......
2 GMS .32's
2 hayes 6 oz fuel tanks
5 hitec 311 standard servos
2 9x6 apc props
a set of Keith Sparks plastics
2 GMS .32's
2 9x6 apc props
LA
Here is a link to Model Airplane News and an address for the plastic parts from Mr. Keith Sparks. The article in Model Airplane News has Mr. Keith Sparks contact info.
http://www.modelairplanenews.com/plan/fsp0701a.asp
PARTS
Yes, I still make the parts. The article said that the parts will cost $30, there is a problem. The white plastic that was used is polystyrene,$7 per sheet. The problem is that after it is exposed to fuel and vibration it cracks after around 10 to 15 flights, this just wont do. The article is 3 years old and so is the plane. After trying different mounting designs; I had to switch to PETG plastic for the cowl. that's $19 per sheet.
1 set = 4 cowl halves, 2 upper and lower wheel wells, The round part at the aft tip of the fuselage. the instrument panel, cockpit seat and canopy. So the bad news is that I have to charge $40 for the parts plus $4 shipping I'm sorry for the price change, I'd rather apologize for the price rather than the parts.
TO ORDER THE PARTS
Send a $44 check or money order ( m.o. is faster) to:
Keith Sparks
7755 Nor-east Dr.
Fort Worth Texas
76180-6805
PARTS
TO ORDER THE PARTS
Keith Sparks
7755 Nor-east Dr.
Fort Worth Texas
76180-6805
The more I see of that plane the more it really makes me want to build it. I have some old plans that I bought like 20 years ago that is designed for a .60 2 stroke to be mouned in the nose. I've thought about building it, but when I saw these plans with the twin .25's in the engine pods and decided not to. I'd like to see more pictures of the build and the finished plane if possible. I assume looking at the posted pictures that it is designed with fixed landing gear, but do you think there is enough room in the wing pods for small retracts?
LA
Yes as a matter of fact it normaly needs nose weight. I spoke with Keith Sparks and he said retracts would be fine. Keith was very informative and the plastics that I got from him were very nice.
Way cool...
I am building the same plane also. I am stuck in a couple of places. I'd appreciate your friend answering them if possible?
Where do doublers D1 and D2 go and when do you glue them on?
Here are some pictures of mine with retract positions as I figured them.
Any help is appreciated.
Sina
Sina
LA
Here are some more pics of the build up. Mr. richard is a quick builder! I can't keep up with the pics.... i'll get back with Richard on d1 and d2.
LA
the following is from Keith Sparks F.A.Q. list if you would like all the F.A.Q. i can email them to you. hope this helps
How does D1 and D2 fit?
D-2 is a little smaller and fits against D-1.
This extra balsa was needed so you can sand a radius in the fuselage just aft of the canopy and forward of former 4 (F-4).
Personaly I preffer to use wood workers glue because CA causes hard spots in the skin and shows through when you monocote. I used allot of "T" pins to hold the doublers in place while the glue dried.
Thanks. I have the same FAQ from Keith, but still can't figure out if I am suppose to glue D1/D2 to the skin before bending it around or after? If after, then does it go on the inside? thanks, Sina
LA
Mr. Richard said he trashed d1 and d2 and made his own pieces. They fit on the top of the plane right below the pilot. He also added a piece of stock balsa below them so he had something to glue it to. whew! hope this helps
I just posted a bunch of picutres of my fuse progressing, here: http://www.rcuniverse.com/forum/fb.asp?m=3244210
Nice. How did he do the covering? I'll be shoping for mine soon. I'd appreciate the monokote number for the olive and the cream. sina
You can buy the "short-kit" from this guy for $95 http://www.tanks-hangar.com/Store/store.html
I ended up doing my own.
I picked up one of the two .25Fx n eBay. Looking for the second one. I got as far as aligning all the parts to install. Taking my time as I tend to mess up at this stage.
Will post pictures on my other thread as I will be covering soon.
Sina
Sina
LA
the colors and numbers are as follows
olive drab green solartex 2 meter roll #557 this is from Balsa USA 800-225-7287
creme monokote th3127
dove gray monokote th3131
the plane is finished we have been breaking in the engines and fine tuning the carbs then Katrina struck. we are all alright but have not been flying since the storm. and then the mower at the flying field died, we are in the process of getting a new mower. when we maiden the A-10 i will try and get some digital video! stay tuned............
Hi guys
At last i've found some people with the same kit![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
I've just got the plans, plastic kit and the wood kit
Going to get a 8'x4' sheet of ply at the weekend and hopefully start building soon.
This is my first hand built model too, so i hope you guys don't mind me asking question as and when i get stuck!
LA
well the plane was in a severe crash due to one engine flaming out! Mr. Richard Guidroz rebuilt it with one engine and it fly's nicely. I'll get some pictures up soon
