WK-G007 gyro, servo limit?
Is the Extent (servo travel adjustment) pot on the Walkera WK-G007 supposed to work or is it just for show?
I have been trying to set up a WK-G007 gyro, and having used Futaba gy401 gyros for the last 2 years I must admit that this gyro copies the 401s function in every aspect (at least on the ground). But there is one exeption, I can't limit the endpoints of the rudder servo to prevent it from binding, no matter how I turn the Extent dial the servo still travels as far as it will go and binds.
Isn't the Extent trim supposed to work like the Limit trim on the 401 and limit how far the servo will travel or is this particular gyro faulty?
FL
You could have a faulty Gyro
the extend limits the servo travel. Mayne your giving it to much
remember it starts at 0 for almost no movement.
ORIGINAL: Magnus G
