Walkera 22e won't lift off at full throttle
Hello,
I am pretty new to this hobby. I am just learning to fly. I was flying my 22e yesterday when I had a pretty minor crash. Now when I go to fly, it will not lift off at full throttle. I have looked over the rotor head and can't see anything broken. I have noticed that when I start to spin up the blades I have pitch and roll controls but at a point in time as I spin it fast I loose those controls and the helicopter just sets there on the ground when the blades are at full throttle. Does anyone have any idea what is going on. Thanks[
![Embarrassment](https://www.rcuniverse.com/forum/images/smilies/redface.gif)
Check to see if the nut on the bottom of the blue aluminum T-block has come loose, or if the set screw in that block is loose allowing the T-block to slide up and down on the main shaft.
-JT
-JT
AA
Check your swash plate... sometimes mine comes apart amd you have to press it back together... this will cause you to have zero lift but full speed rotor head
