11.1v battery in 22e
HI,
I have just bought a 22e with the standard 10.8v battery. Is there any mods to do to change to 11.1v lithium
Hello moir,
I had the 22e and did upgrade to brushless with the Walkera 180L Brushless motor. I used an 11.1v 1200mAh Lipo with that setup. For the weight the lipo was fine, but bear in mind if you aren't planning on going brushless then the chances of your main/tail motor burning up are increased due to the longer duration of the battery. I only upgraded my main motor to brushless, my tail did eventually fail but i was only 1 foot in the air. Luckily.
ORIGINAL: moir78
HI,
HI,
