fms and transmitter
Hi all
brand new to helo's so wanted to try the fms, software runs ok
but cannot get xp to find the transmitter what sort of joystick setup does it need using the supplied sim cable to the com port
is it powered from the pc or do I need the batteries turned on ?
anyone able to help
anyone able to help
Hi,
If it's like mine, then the cable goes from the trainer interface on the transmitter to a USB port on the computer. The transmitter does have to be turned on...it doesn't get powered from the PC.
Welcome aboard the forum!
Will
Will
thanks for the reply Will, but my cable only goes to a com port and is not usb compatable
just crashed my heli so trying to source spares in the uk, not sure where to place the battery seems it was too far forward and nose dived. live and learn!!!!
Wow, your computer is running XP and it actually has a COM port?
(I haven't seen an honest-to-goodness COM port in a while...)
Sorry to hear about your crash. We've all been there. I've only recently gotten to the point where I can fly with reasonable confidence that I won't break anything, and that's only with TI enabled. I'm still awful on "my own." Which model of DraganFlyer do you have?
Will
![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
Will
Hi will
yep got a com port will try and source a usb cable tho
as my com port wont detect anything was trying to fly the 4#
and what is TI seen it mentioned but cannot find what it is.
many thanks
Tony
many thanks
Tony
ORIGINAL: atonydins
many thanks
Tony
many thanks
Tony
TI stands for "Thermal Intelligence" and is the infrared horizon detection system used to allow the DF V to self-level when being flown outdoors. (It doesn't work indoors, though.)
Good luck with the sim!
Will
FL
I just received my FMS interface cable and sim software from DFI, and have to say that this is a GREAT tool for training. I haven't assembled my DFV-TI but I used to have one of the old Roswell Flyers. Sure wish I had a sim like this back then. Hopefully, I won't need nearly as many of those spare parts as I ordered ![Smile](https://www.rcuniverse.com/forum/images/smilies/smile.gif)
Rusty
Rusty
Hi guys
thanks for all the replies, Santa was late but today I got my E-sky usb simulator, and it works, after trawling through the forums have made my #4 less twitchy by moving the servo control rods towards the pivot point.
again many thanks and a happy new year to you all
Tony
Tony
Hi there,
I just recieved my Walkera Dragonfly #4 the other week along with the FMS fligth sim. The cable supplied was TX to serial, so I bought a serial to USB converter, but I still can't get Windows XP to see the TX. Any suggestions!!!
Cheers
Cheers
With the DF4, you can use PPjoy with the supplied cable connected to a serial port. Search for "Zhen Hua" for info on how to set it up.
-JT
-JT
this has all you'll need.
http://www.dkgoodman.com/dragonfly.html
BTW if you want to save your batteries, take the xtal off. It will drain your batteries six times less. Remember to plug it in after you finished up with your sim or you will forget to take it to the field.
Hi there XAR...sorry this is soooo late a reply...new to the Walkera 4
and want to use FMS sim...how do you turn off the "xtal" on the Tx
to save batteries...thanks, John H.
Hi Mike...thanks for the reply...but what exactly is the xtal and
where is it located?...obviously I don't have one of the TX's in hand
...but, if you can describe it I can figure it out..thanks, John H.
MD
No worries. The xtals are the small silver crystals that drive the TX and RX.
On the back of the tx, there is a plastic cap with the frequency # on it. Remove this plastic cap/cover and the xtal will come out with it.
To be honest, not much battery life is saved when you do that. But it is a good idea as not to put out unecessary RF. You may have a neighbor flying in his basement and it could cause him a glitch. Rare to be sure, but possible.
Hey there, I'm new to helos and I am trying to set up fms for my falcon 40. I can use it with the keyboard but not with my controller. I bought an adapter cable to run serial to usb. I think my error is in the set up. I'm not sure what number to place for what functions. Also, what is inv and exp? My choices on the functions are tail, nick, rool and pitch. Thank you in advance for any assistance.
Hi Marcus...practice on FMS is highly recommended....it's a great SIM to
begin with...this is an Eflite forum...suggest you check on a forum devoted
o the Falcon or its manufacturer...that said, if no luck, search for posts by me,
JMHH, related to FMS and you'll see an extended discussion (by me and others)
on using FMS with the Eflite BCX2 TX...cheers, John H.
Hi Kevin and all...have used FMS with the BCX2 TX with great
success with Helis..decided the other day to try it with planes
...what a hoot...but, when I reset the plane to start flying,
the plane starts to take off...can't seem to trim throttle low
enough to make plane sit still to start...this is not a problem
with the Helis..the plane otherwise flies fine, save landings
are not realistic as I have to come in so fast...any thoughts
(anyone)?..I also have Real Flight G4..it's really great, but
a tad expensive, but worth it I think...the possibilities are
almost endless.....cheers, John H.
Hi Kevin...read link...using BCX2 TX...but similiar set up
..just can't find fix...tried several throttle settings
..no biggie, as all works well with the Helis...cheers,
John H.
John H.
