Walkera 76c. advice???
Hi everybody i'm new to all this and flying heli's also, so i hope someone can understand what im going on about. I just recieved my walkera 76c and apon trying to fire up the main rotors i relised they werent going to work. So i fiddled with the swicth at the back of the remote and changed the throttle to the off pos. Then worked when i wasn't expecting it.. flying off and hitting the TV. Anyway it seems to be running out by about 5mm at the very top of the rotor. Has anyone else got walkera 76c and is that normal. It dosn't seem to put a huge amount of vib through the unit, nothing seems bent and i think it will still take off fine but what do u guys think?????
Their is a small diameter drive spindal that connects the big main drive gear driven by the electric motor to the rotors at the top. You will find this is bent or the rotor slide assembly is not affixed to the small shaft correctly (it is held on the shaft by a small pin etc) Good luck
