YS 91 AC or new YS 80fz for Warbird Racing
AZ
Looking for a recommendation as to which engine would be best for me to use for a Silver class warbird racer. Which engine would give me the best torque the YS 91AC or the new YS 80fz.
Both motors would do great if racing in Sacramento. I personally would match the plane to the engine and use the motor that works best with the airframe. With that said the 80 would be new and come with warranty and support from YS parts and service whereas the 91s are getting harder to find. If you were using a world models P 51 either motor would work by placing the gear to off set whichever motor is used. We have raced the 70 in silver with great results on multiple airframes. The 80 would use a little less nitro and be a great fit.
AZ
Thanks Jimmy I ordered the world models spitfire and will probably purchase a new YS 80 then adjust Nitro to hopefully get me around that 2 minute break out speed.
Thanks again Bob
Thanks again Bob
The FZ80 S is the best engine that Yamada San has ever made in this case - 53/63/70/80. There are a number of improvements: 1) spiral oil groove on valve lifters, 2) much better carburetor, and all of the 70 improvements.
The different carburetor means the the main needle runs at about 1 turn open. On your first tank don't get discouraged, keep turning it in. Later engines may not run here !
I want another one but they are out of stock at central hobbies.
