Ys63 fz Brak in/oil
Ys63 fz Brak in/oil
Hi Dave,i just buy my first Ys engine, for my Seduction fs, can you help me?
The first answer is on fuel, in Italy we run Motul Micro, do you Know this oil?Suggestion?
The secon answer: i can break in the engine directly on the model, or is necessary go on engine stand.
Third, how can refuel, by the pressure line or the carburetor line.
Thanks Carlo Cardinale
Ys63 fz Brak in/oil
Sorry, but I am not familiar with the oil you are refering to.
You can break the engine in on the airplane. Run a couple of tank through it on the ground to get the needles set and go fly it.
Make sure the top end setting is rich.
Fill through the fuel line between the filter and the tank. You will have to disconnect the pressure line between the check valve the the tank to use as the overflow.
Good Flying,
Dave
Good Flying,
Dave
