Falkon ignition
![](/forum/images/badges/trading_plus_member.png)
My Feedback: (13)
PA
I was looking for help. I have older rv 80 with Falkon ignition . The timing has bin moved how do reset ignition? zdz rv80 bing carb prop 26x10 rpm 5620 temp 220. Ken
Simply adjust the ring so that it is a max of 4-5 mms before TDC. You can also move it closer to TDC but do not let it fire at or past TDC!
How it runs and starts will determine the final setting.
Good Luck.
k_caller
Good Luck.
k_caller
