OFFICIAL RC18MT/B/T THREAD
#3427
@scab, thank you........very useful information....
@ da beast, well i think you have two choices, the stock plastic ones or the factory team aluminum ones. I use the stock plastic ones and they work fine, i havent used the aluminum ones as i have read they leak a little more. I do use a much heavier shock oil weight though, 30-35 weight oil, i might change the 30 to 32.5, but im still thinking about that.
#3428
CA
IMO, either one of these are the best on the market. Only Difference between the two other then manufacturer, is the shade of blue you like better.
[link=http://www.thetoyz.com/cart/thetoyz_details.lasso?id=8912&cat_name=]3 Racing's Set[/link]
[link=http://www.thetoyz.com/cart/thetoyz_details.lasso?id=7952&cat_name=]The Toyz Set [/link] *I know they are labeld as 3Racing now, but they used to be branded under TheToyz label.*
#3429
NJ
ORIGINAL: Mousesi2k
#3431
ORIGINAL: 93dabeast
i need something durable and that can take abuse.
These mini's don't take "abuse" too well. If you wanted something to beat on, maybe you should have stuck to a larger scale.
#3432
MA
I noticed the RC18MT is still a shaft driven design. Whats the concensus on which is better? The newer T2 belt drive version or the older shaft drive version? Im gonna pick up another kit, but I can get the older shaft drive version with a cheaper 2 channel AM radio or spend $10 more for the newer belt version with the 3 channel 2.4gig radio.
#3433
ORIGINAL: ntrain42
To me, they're not really "basher vehicles" nor are they for the uninformed and unfamiliar.
Just so you know, I have it on great authority that AM radios cost more to produce than 2.4gig models.
#3434
MA
ORIGINAL: crunchNmunch
Any beltdrive vehicle is going to be more maintenance intensive and require more upkeep and care.
ORIGINAL: ntrain42
A little more maintenance with belts is OK on my part, performance though I would assume is better with belts with less friction and rotating mass in the drivetrain, but again, Im not familiar with these small scale models.
#3435
ORIGINAL: ntrain42
They may cost more to produce(crystal sets I bet increase cost), but they don't perform anywhere near as well.
It's not just maintenance, which bashers are the worst about doing, but being able to fine tune the adjustment.
A rookie just doesn't have the expertise needed to deal with it, and even the experienced guys are stuggling with the new 18t2 belt systems.
AEhad to redesign the front diff housing, and they're still having issues with it. Just not worth it to me.
Same motor - overall performance difference, as in top speed, is going to be negligible.
#3436
MA
A cheap radio is still a cheap radio. I've never had a 2.4gig, always used premium AM/FM radio and never had any problems.
ORIGINAL: ntrain42
Regardless, can the RC18T2 be converted back to shaft drive? Looks like ALOT of the parts are interchangeable, just curious if this can be done?
#3437
ORIGINAL: ntrain42
In one sense I agree with the radio statement, but in another sense, I definetly would rather have a cheap 2.4gig radio, vs a good quality AM/FM radio when it comes to range,feedback and lack of glitching. My old Futaba PCM 1024 does not respond to or have the range that these new cheap 2.4 gig radios have I can say that.
Any radio can be made to glitch, including the new 2.4gigs (ask my buddy), as glitching is seldom if ever the radio's fault but the actual installation of the rest of the electronics.
I still can't understand why people talk about "range," when the fact of the matter remains that when you can take most any car using about most any radio to the end of the next block any further than that is totally pointless. I had one of those old PCMs back in the day when they first came out, and I still think it is one of the best ever radios. I never had any glitch or interferenceissues.
The new 18T2's are a totally different vehicle and drivetrain. They share no internal/chassis driveline components with the earlier 18T's.
Suspension and axles are the same, but little else is.
#3438
MA
If you look at the cheap 2.4gig radios, they generally are just new 2.4-specific guts in the same old junk body used previously. Only thing that changes is the frequency. The rest of the radio is still junk. Everybody seems to be obsessed with the 2.4gig technology, and while the ease of use is understandable relative to not having frequency conflicts they can't reasonably perform any better than the radio they replaced. Range is totally relative to transmitting power, and transmitting power comes via the voltage (how many batteries) your radio uses. So in reality many of these newer 2.4 radios have a lesser range because they're using fewer transmitter batteries.
ORIGINAL: ntrain42
#3439
ORIGINAL: ntrain42
]Oh, I know the bodies are cheap, many of little adjustments past basic st./th. trim, but the range from what I have(DX3S and DX3R for Spektrum and the AE XPD 2/3 channel stock 2.4gig that now comes with some of the RTR kits like the RC18T2 etc)and response is excellent. Ill focus on the AE XPD 2/3 channel radios specifically. I never get any servo twitching at long ranges, and the range, its beyond my comfortable vision and field of view Ive found with never a hiccup. My Futaba PCM 1024 on the otherhand twitches and loses some control at just over half the range of the cheap AE transmitter. Then there is the deal with never worrying about frequency changeout etc. For me these benefits outweight any potential negative, especially for bashing. But for racing, thats a different story as Id prefer something like a DX3S/R from Spektrum or an M11X or 4PKS for the immense adjustments,model memory,nice grip feel etc.
Do you have an automobile or TV from that era that you're still using, without any potential old age related issues?
It just doesn't make any sense that you're comparing any radio that comes with an RTR, 2.4g or not,will compare with a high-dollar Futaba or Spektrum.
![](http://www.rcuniverse.com/forum/js/fckeditor/editor/images/smiley/msn/sad_smile.gif)
Apples and oranges.
#3440
Realistically, how old is that Futaba PCM you're talking about? 15 or 20 years old?
It just doesn't make any sense that you're comparing any radio that comes with an RTR, 2.4g or not,will compare with a high-dollar Futaba or Spektrum.![](http://www.rcuniverse.com/forum/js/fckeditor/editor/images/smiley/msn/sad_smile.gif)
Apples and oranges.
Apples and oranges.
As a matter of fact, I do. I drive a 86 mazda rx7, and i plan on never selling it.
Now on to more relevent issues, am/fm radio's are glitchy, bottom line. Sure I guess you can spend a whole lot on a am/fm tx/rx, but why? when the $100 dx3r setup works just great, no glitching, far enough range to where it becomes hard to see the rc, 5 model memory. But i think the both of you are forgetting one very important factor, it doesnt matter how many cars run together, 2.4ghz are always locked. Vs am/fm, you have to check and make sure no one else is running yours. THAT is the main factor here, i think.
AND
As far as that begginers cant handle the belt drive....are you serious??? this isnt rocket science, its like advance K'nex, lol. And since its not an onroad car, what adjustments???? Unless he planns on racing, its not even like there is a worry for camber or anything.
AND
Sure these little guys are not as durable as the 1/10 scales, and the 1/10's and not as durable as the 1/8s, but for the size, these guys are not cheap little toyz. I take mine on the track, bash in the back, so far my spur gear is the only thing that Ineeded to replace, and that was due to me trying to push something over 5 lbs, and then i tried to flip a 1/10 at the track, seemed like a good idea at the time.
Personally if you want to try a mini, go on craigslist and grab one of the many that are on there as it seems alot of people are selling the driveshaft version to get the belt drive. sure the beltdrive is a better setup, but that by no means states that the drivedrain is a crap setup. Plus you will Spend about half on C.L. too. If you like it, go after the beltdrive.
#3441
ORIGINAL: r/c_freakNow on to more relevent issues, am/fm radio's are glitchy, bottom line.
I've been using AM radios exclusively for 20 years, and never had a glitch issue I could blame on the radio or didn't solve quickly.
With everybody seemingly jumping on the 2.4-bandwagon, I've only had a frequency conflictat a race ONCE in the last two years.
Bottom line, if you can cure a glitch you can't handle setting up a beltdrive car..
![](http://www.rcuniverse.com/forum/js/fckeditor/editor/images/smiley/msn/wink_smile.gif)
#3442
I beg to differ.
Bottom line, if you can cure a glitch you can't handle setting up a beltdrive car..![](http://www.rcuniverse.com/forum/js/fckeditor/editor/images/smiley/msn/wink_smile.gif)
#3443
ORIGINAL: r/c_freak
2.4ghz, glitch cured, and if you havent had many frequency issues at the track, dont you think the 2.4ghz has made it so, its great that so many people can get together and have fun without issues, i remember when i had to wait for the person on the track to finish, no more waiting
I didn't mind waiting for a frequency clip, what bugs me now is when 25 people are on the track at the same time during practice because they all are on 2.4... just because they can.
#3444
))))))))))))are you serious??? this isnt rocket science, its like advance K'nex, lol.)))))))))
the amount of people who have said things like that. then come back to me with a bag of bits saying what went wrong. lol
i say i did try to warn you that the motor does spin very fast and it has a hell of a lot of power. so even if one thing is not set up just right. it can do a lot of damage in the $$$$
#3445
Tell that to all the guys that have glitch issues because their electronics are a tangled web of a mess, seen it happen dozens of times.
I didn't mind waiting for a frequency clip, what bugs me now is when 25 people are on the track at the same time during practice because they all are on 2.4... just because they can. [img]images/smiley/msn/wink_smile.gif[/img]
ORIGINAL: turok007
#3446
ORIGINAL: r/c_freak
Well your just too hard to please. Look at it this way, if you can drive the track with 25 cars without messing up, imagine how well you will do at race time, only 10 or less cars. Personally Iliked it when the track is full, its more fun for me.
I can get around just fine, it's all the rookies that I spend too much time ducking and dodging to make it not worthwhile.
#3447
it's not being lazy. it's just many people think they are dealing with a toy. so they get well out of there depth. i know of car mechanics who have 30+ years experience. but they cannot build a RC car or set it up.
#3448
MA
ORIGINAL: turok007
![Wink](https://www.rcuniverse.com/forum/images/smilies/wink.gif)
#3449
ORIGINAL: ntrain42
Those arent very good mechanics you know then....... ![Wink](https://www.rcuniverse.com/forum/images/smilies/wink.gif)
ORIGINAL: turok007
#3450
ORIGINAL: turok007
