Rudder Only Design
ON, CANADA
Rudder Only Design
Hi All,
For the Design Contest, I am building an .049 R/E/T plane.
I would like to be able to set it up so I can flick the Mix switch on the Tx, which will leave me with only rudder control.
The goal is to do a Cuban 8, like they could in 1957 :
http://www.airplanesandrockets.com/r...ft-modeler.htm
From that article there is some trimming tips, but I'm looking for basic R/O design setups.
Like wing incidence, downthrust, dihedral, etc.
The design will fly R/E/T at 0 downthrust, +1 wing/0 tail incidence
I will make it so I can 'field adjust' the wing incidence and downthrust for R/O.
Any help will be appreciated.
Cheers,
Dave'crosscheck'Fallowfield
Maac 6437
Unabashed Combat Team
Cheers,
Maac 6437
ON, CANADA
Hey CP,
That 1957 article mentioned needing more power to do loops !
.35 was SMALL back then!
All sheet balsa construction, simple is Hard !
Cheers,
Maac 6437
Cheers,
Maac 6437
http://www.colinusher.info/Model%20A...der%20bug.html
http://www.airplanesandrockets.com/r...ft-modeler.htm (Same article??)
As a trend I'd say (without implying great insight or wisdom here!):
3-5 degrees downthrust (to prevent looping etc under power with the built in trim)
Right thrust as necessary (to keep it straight under power and prevent tightening up left turns too much I guess)
2-3 degrees decalage (smooth glide trim)
Enough dihedral for stability and rudder authority, less than pure FF
But as this article implies, the exact settings are aircraft/power specific.
ON, CANADA
Thanks MJD,
I've tried it a few times with RET (Sig Kadet Jr, Randolph BeeTween and a Cox Centurion) by giving enough up trim for a steady climb.
Could 'slalom' upwind and get basic circuts OK,
But when I tried 'the spiral' for speed... there was no 'up'... (just speed!)
So I'm guessing it is a combination of decalage and downthrust. And perhaps a fwd CG for a glide with alot of decalage.
I can adjust the wing incedence with shims.
With a 'double' firewall I can make downthrust adjustable.
And easily field change engines, for more power, if the wind comes up...
(I like the part where you have to roll to get upwind !)
That reminds me...
I need to consider a RE Piped .049 looking good with downthrust !
Cheers,
Maac 6437
That reminds me...
Cheers,
Maac 6437
Did I ever get those picture files from you? I'll send you a PM with my email.
CC the way I set up the model in the pictures was to put the balance point a little ahead of what is normally done. Then I shimmed to set up for what looked like a good glide. But if you use your elevator you can use that as a trimming device instead.
As it happens the model shown is all together and sitting out so I was able to quickly check the CG location. It's 2 inches back on a 7 inch chord. So that's 28%. Then the model was test glided over the proverbial tall grass to set the shimming of the wing and tail to get a reasonable glide. Here again since you'll have "carried along shims" courtesy of the elevator you can set the balance then just trim once flying for the right climb under power and glide when the engine is off.
The trim that results from this balance point climbs fairly strongly under full power. In the case of the model you see it has roughly a 5 degree nose up climb at a fair flight speed which gets the model up to around 250 feet in about 30 to 35 seconds. From there I use the rudder to stunt up a storm of different loops and rolls. I can even manage a pretty decent Cuban 8 when flying it regularly by just rolling it back upright just a hair after the top of a loop.
You'll find that it requires a heap of downthrust to hold the nose down. Mine has a good 5 to maybe as much as 6 degrees relative to the center line of the wing airfoil. You won't get away with much less than that.
As it happened I found that the glide trim turned out to have a slight and slow stall bobble. I thought I'd want to trim that out but in fact I found that I was able to use this to allow shallow bank turns without the model diving. So I'd suggest you try the same glide trim and see how it works out.
Here again when I was on my game I could make my landing approach such that I'd level out from the last downwind leg turn with the model about a foot high just as the wings leveled. And the extra speed from the turn would be just enough to flare the nose up without actually climbing and the drag that came with the stall would slow and lower the model onto it's wheels before the break to a dive. When done well, which I was able to manage about 1 in 5 you'd swear that I had an elevator. When I'd nail it I made sure to hide my excitement and try to make it seem normal and regular....
The dihedral on the model shown isn't that much. But I suspect I'm getting some additional help from the beveled wing tip shape you can see in the second picture.
ON, CANADA
Thanks Bipe and Bruce !,
This helps allot for me not 're-inventing the wheel' as far as R/O goes !
I'll have the elevator to 'bail out' with, if need be.
I am considering an HS81MG for firewall downthrust adjustment, rather than a throttle !
I think I am close to the ballpark. (pun intended !) Design wise.
Making room for the gear I have, with options for lighter stuff.
Snagged some nice 1/8th balsa from a LHS...
Project well on its way...
Just have to simplicate, and add lightness !
Cheers,
Maac 6437
P.S. Several of the old school designs have swept back rudder hinge lines. Asthetic, or practical?
Cheers,
Maac 6437
ON, CANADA
Hi Bipe,
I don't know...yet!,,, about the rudder hingeline...
I'm going for the 'looks cool' effect.
The further away, I get from an LST...
Makes this project :
A- Stupid
B-Possible
C-Might work
D-Don't worry
E- Will beat the pants off anyone else entering...
Answer, All of the Above !
Cheers,
Maac 6437
A- Stupid
B-Possible
C-Might work
D-Don't worry
Cheers,
Maac 6437
