Cox Tee Dee .051
It has a lot of wear. It will poke through soon. The ball socket was likely not reset over the years, and/or there was not much oil in the fuel. You can get a replacement still from Cox International. An .049 one is fine too. The .051 piston is a bit heavier, and there is a bit more stress on things.
If you get a reset tool you can try a reset and it may flatten the head back allowing you to continue to run the stock piston. I am not sure they carry .051 pistons.
Sometimes they will get in old stock still in the package or will refurbish parts for resale.
It might just be a bit poorly machined, in the Estes era anything would go out to customers...
The reset tool should have a recess in the center to allow for these kind of errors, and to avoid deformations to the piston itself.
I looked at the full-sized photo - it looks like the ball may be peeking through the top of the piston at this time. If that's the case, it's time for a new piston/rod/cylinder. I had a TD .049 many years ago that did that. I was out of Cox fuel so I went to the lhs and he sold me a jug of 25% racing fuel. He told me "Oh, yeah, it's got plenty of oil". After ruining a TD and a Queen Bee, I checked further and the fuel had 14% oil, mostly synthetic. Lesson learned the hard way - at least 20% oil, at least half of that castor.
