Which plane for the E flight 1360kv outrunner?
CA
Well, the Tensor is dead and I just don't feel like building another one. I loved the way it flew but it seemed a little too fragile. What plane would work well with this motor? I would prefer a mono plane and would like a good thrust to weight ratio. Thanks for the suggestions in advance.
![](/forum/images/badges/trading_plus_member.png)
Bruce,
Anything that comes out at 10oz. will work. The most cost effective thing to do would be planes from Foamy Factory and material from DepronUSA. I was flying a larger version of the YAK which is an easy build and goes together fast. For $30 you'd get enough material to build 2 or 3 and they fly really well.
My tensor has held up so far but your right about it being fragile. I worry about it as much during transport as I do while it's flying. I might build a carrying case out of Luan.
My Feedback: (73)
Try one of the new planes from www.rcskydiving.com They have 2 planes now available, Edge 540 and a Pitts S2S. Both fly extremely well,but the Edge is the most stable,smooth foamy I have flown to date.
I just maiden my Tribute with a Park 370 outrunner, CC10, HeCell 3S 2000mah 6C lipo pack, had a hoot, This is my first attempt at trying to fly 3D so I can't compare the plane with another one but I was having fun. The landing gear is a little weak imho. So I had to reinforce it...other than that I think it's a fun plane to fly. I must have flown it for about 10 to 15 min...recharged the pack and put in only 1000mah....so I could have flown even longer.
Hope this helps.
Gord.
Hope this helps.
Gord.
