parkzone typhoon
parkzone typhoon
Has any one flown a parkzone typhoon? Im not getting one anytime soon but if i get some positive feedback about thtyphoon i might consider saving up for one. Any help at all would really be good. Thanks.
TX
RE: parkzone typhoon
Got one sitting over there <------- Anyhoo, it flys well. It is aerobatic and it will hover. Great roll rate. It is heavy compared to others, however for a 100% turn key airplane, the Typhoon does well.
I like the Mustang 10 times more than the Typhoon.
NE
I have about 100 flights on mine & overall I think it's a good plane for the money. It is capable of 3D with the stock setup but the servo's tend to strip out on high rates. (at least in my experience).
It's fairly durable in the sense that I've had some pretty hard hit's where it kept on flying or was easily repaired with some CA or tape. I completely pile-drove it once at near full speed & it cost me about 40 bucks for a new fuse & motor mount & I was back in business.
I personally use it as a sport/aerobatic plane and mostly fly it on low rates & have had no servo problems in quite a while.
I have read threads where owners are upgrading the servo's to Hitec's (for about $60) & it does a lot better.
Tony
Tony
thanks a lot! how fast is its vertical flight and at what power does it hover. im thinking of getting the typhoon as a 3d trainer and im try to gather up as much info as possible.
NE
ORIGINAL: passionatepilot
I'll admit that I don't do much hang from the prop 3D with it so the others can probably give you better advice.
im glad to here all this because i heard that parkzone sometimes make some dodgy models but it turns out that the typhoons a real success. I must of got a mental blank or something but whats TX short for again?
radio i think most of the park zone stuff comes with a transmitter if you really think your going to get into 3d the last thing you want is another radio and more nicades save your money for a good transmitter and a brushless motor that you can swap around into other planeslater on cheers ps- wher abouts in melb
NE
A buddy of mine has a 3 channel Cub & he hates it because it's hard for him to fly. My 11 year old son has a $50 2 channel (not parkzone) & he doesn't like it very much either because it's hard for him to fly. They both love my Typhoon mostly because it's a 4 channel.
im going to by a 6 channel hitec or futaba radio and ill brobably also get a brushless motor with the transmitter. I think ill get the typhoon plug'n'play to save me some money and to have some better quality stuff such as a lippo battery. By the way, do any of you know how much the typhoon plug n play costs?
i know. i was looking for the typhoon (not to buy it) in a hobby shop but i coudnt seem to find one. i thought they might have just been out of stock or something.
Passionate pilot ilive on 3 acers in the central gibbsland area a fair way from where you are i mostly fly at home i have a mate two doors up he also 3 acers with planes and helis if you look at the thread black horse extra 300s youl see what i fly in the pics i got adicted pretty quick and loveing it cheers
its a nice looking plane! i'll get the typhoon plug n play version, learn of that and maybe also get an extra. i know there usually fuel but was this one electric?
yea it was elec to begin with iv only just started fly the extra iv done about six month on the lighter no so expensive jobs the ones that are hanging on the wall i found the extra being abigger and heavea plane much easyer now after doing time on the lightewr stuff
if i get a 6 channel radio how many planes would i be able to fly with it? because im first getting a cessna skylane arf then the mustang and then the typhoon. after that i might go into something more advanced such as the funtana or an extra
My Feedback: (14)
FL
the parkzone typhoon is a really nice plane for the money........i did change the servos before flying mine and have had no problem with the plane. well worth the money...[8D]
if you have a look around the hitek eclips 7 you will pick up for around 400 dollers with a few goodyes 4-sevos ,recever.When i got mine i had my LHS swap the 4 bigsevos for 6 hs-55 he also swaped the 8 channel rec for 2 -4 channel rec ,the eclips-7 you will store 7 planes in it
i was thinking of doing something along those lines. do you by any chance know exatli which bits are missing from the plug'n'play?
and also, does the typhoon have micro servos or just normal ones?
Passionpilot sorry but i havent read up much on the typhoon what do the mean by plug /play dose that mean it allreadyhas sevos and rec
no worries. i looked it up myself. it would actually cost atleast 100 oz bucks more if i bi the plug n play[&o]. the typhoon costs $429 oz at rtf version.
The plug and play version only needs a tx and rx and battery. It has the brushless motor, speed control and servos already installed. I liked the P/P version because I would rather use my 9C instead of the cheapo tx that comes with it. If you have a 3c lipo and charger lying around along with a tx and mini rx you will be in good shape. You can use the 9 cell nimh but make sure you have a charger that will charge 9 cells. You would have to spend money on a charger that will.
i dont have a spare anything lying around. if i had those things i would bye the plug n play straight away. anyhow, im going to bye another plane before the typhoon so ill see how i go. i will definately by lipo batteries though. is the stock set up charger compatible with lipos?
