Tensor motor choice
My Feedback: (29)
AL
Tensor motor choice
Noticed that the completion list for this has the Park 370 1080kv and the 1360kv motor as choices. Which do I need and will either one be sufficent. I will be going with the 2cell 800 mil pack although a 3 cell will probably be used also. I am going with the eflite sub micros and a Futaba micro receiver. Do I need the foam cya or can I construct this with white glue and 5 min epoxy?
RE: Tensor motor choice
Most use the 1080k for 3 cell packs, and the 1360k for 2 cell packs. I like the 1360k with both 2 and 3 cell packs. Use a 10x4.7 prop when using a 2 cell pack and a 9x3.8 when using a 3 cell pack. You are better off using CA, or for the best use Por 15 from Hobby-Lobby.
