Throttle curve help
Hi,
need help to set up a softer throttle response to stop me bouncing the plane around and overcontrolling like an idiot! Unfortunately my tx does not have a curve mix nor multi point only straigh channel to channel with offset any ideas please?
![Wink](https://www.rcuniverse.com/forum/images/smilies/wink.gif)
Sorry very dull, basic transmitter with no multi point mixes no thr curv only the straight mixes with offset. plane is a 3d electric, a hyperion sniper great to fly just very sensitive to throttle for hovering
cheers
cheers
Many thanks http://www.dimensionengineering.com/Expoduo.htm
found this which may do the job
happy new year
happy new year
ON, CANADA
Try having someone holding the plane while you rev it wide open, then back down the upper throttle end point till the motor starts to slow down, then back up just to full revs. This will give you a more linear throttle response from stop to full throttle. Works for me and it costs you nothing to try it.
