Aeroworks 29 % Edge
MS
via the Aeroworks 29% Edge construction manual: (airfoiled tail)
C.G. is 5 3/8" back from the leading edge of the wing at the root end (directly in front of the wing tube)
Aileron: 30 deg high, 20 deg low
Elevators: 20 deg high, 15 deg low
Rudder: Full deflection high, partial deflection low (? that's how it says it...)
I haven't finished building mine yet, so I don't know how well these work out in the "real wolrld". Of course you'd want 45+ deg throw for 3d also. What motor/servos/etc are you running?
