12 ft telemaster motor
PA
building a 12 ft telemaster. I have a hacker a60-20s v2 28p motor with 2 turnigy 5000 5 cells i would like to use in it. will this setup work? I am only going to put a small camera in it to take vidios. wil not be towing. slow flying. about 23 lbs fly weight. thanks for any help..
RE: 12 ft telemaster motor
Hi, that project is a little bigger than Im used to but I would go for absolute minimum 70watts per lb. Now you need to make sure you have the prop clearance (and electrical capability) to reach that wattage. Good luck. Just my thoughts, anyone else?
