Question: Receiver
Question: Receiver
I have a spektrum 2.4 AR7000, was installed in a previous plane involved in a heavy crash, no impact obvious, can I install this in a new plane; if range test and function tests perform correctly. Are there any other tests that could be used to confirm.
Cheers
Cheers
OK
RE: Question: Receiver
You may also try tapping on the reciever as you test each servo individually. If there is any glitches while doing this, the reciever may be damaged.
