NEW Tamiya Kit and Radio Gear!!!
New from Tamiya, the new Volkswagen Golf Mk.1 Grp.2 and Electric Drive Set Fine Spec 2.4G Now at Banzai Hobby!!!
Volkswagen Golf Mk.1 Grp.2 - M05
The Volkswagen Golf Mk.1 was a well-known machine of European touring car racing. The Kamei-sponsored car with its distinctive livery ran in the low-modification Group 2 class of its day.
The Tamiya R/C model faithfully captures the fun and maneuverability of the real life subject as it comes on the proven M-05 M-chassis platform. The M-05 is a simple to build FWD (front wheel drive) machine, which allows for plenty of after-market parts to be outfitted as you grow with your skill.
Also to go with the Kit the new
Electric Drive Set Fine Spec 2.4G (White & Black)
2 channel radio using the 2.4GHz band traveling at more than one is possible without the need for exchange and crystal band management, also with a 7.2V battery and charger for traveling, Radio set is the perfect introduction to electric RC car . Bold design in black with a white grip portion and a control unit, and wheel the body part is a feature. Cover and structure to adopt a trigger grip cover, easy to operate even the smaller hand. Moreover, it was also standard beginner modes in which you can slow down the top speed by the operation of the transmitter. (Electronic Speed Controller) with traveling back function using the high-power FET ESC with aluminum heat sink. High point of the front and rear can be adjusted, also features back cancellation. I also support LF6.6V Tamiya battery. In addition, using a four point happy AA batteries, the transmitter power is also economical.
(ITEM 45056)
【Specifications】
Wheel type transmitter, FET speed controller TEU-105BK, receiver, 2.4GHz specification with servo
***Please Note that the Charger is for Japanese Power Outlets and Voltage***
Please come join us on Facebook for Weekly Specials and Updates!!!
Banzai Hobby Team
(ITEM 45056)
【Specifications】
Banzai Hobby Team
