NEW OVERDOSE Drift Accessories !!!
New Drift Accessories from OVERDOSE Now at Banzai Hobby!!!
Aluminium Rear Upright for Yokomo Drift Package
These Awesome Rear Uprights from OVERDOSE are a Fine way to Dress your Yokomo Drift Package to get that Extra Bling an also to have High Quality Parts a great way to stand out in the crowd between your friends and other Drifters!!!
Aluminium C-Hub & Upright Set for Yokomo Drift Package
Another Fine Example to get mush needed Bling on your Yokomo Drift Package a awesome way to get the Attention you want from the Other Drifters with the High Quality OVERDOSE Products!
Aluminum Shock Cap Set For TRF Tyep-2
For those who want the Great look an many colors to pick from to add to your Tamiya TRF Dampers these Awesome looking aluminum Shock Cap Set For TRF Tyep-2 are a great place to start with the High Quality OVERDOSE Product!!!
Get in Quick as these are a HOT HOT HOT Item an they wont last so don't Delay an get in before they are all gone OVERDOSE are a true fine Example of high end quality Drift products!!!
Banzai Hobby Team
Banzai Hobby Team
RE: NEW OVERDOSE Drift Accessories !!!
New from OVERDOSE The Aluminum Steering Crank Set for Yokomo Drift Package now at Banzai Hobby!!!
In 7 Awesome Colors, these are a great way to get more steer an more angle from your Yokomo Drift Package!
It is the appearance of the Drift Package aluminum steering crank. Set to 3 places the tie rod mounting position in order to respond to the situation and run various. In addition, I adopt a step-adjustable link that allows you to set up a small quantitative. Steering link adjustable length in 0.5mm increments is based on allows for quick and accurate setting change. It becomes possible to set up Ackermann ratio perfect in combination with OD1298 Aluminum C hub and upright set, but, in combination with the normal upright is also possible of course.
Get in QUICK as OVERDOSE sells fast !!!
Please join us on Facebook for Weekly Specials an Updates!!!
Banzai Hobby Team
Banzai Hobby Team
