How to PUSH NiMh cells
Okee, i want to push my new 1100 MAh cells. The internal resistance must go down. The cells must be able to handle 20 amps or more. Can anyone help me with a link to a site with details? Or is there a simple manual [img]i/expressions/face-icon-small-smile.gif[/img]
Banned
You can not reduce the internal resistance of a battery. You can only replace the battery with one that has cells that already have a lower resistance.
Attempting some of the "tricks" to reduce resistance in a battery leads to premature battery failure, and you never will see the reduced reistance you are looking for... unless you internally short a cell, which means you turn it into a lead weight.
Hehe, i just bought Pushed cells [img]i/expressions/face-icon-small-smile.gif[/img] normal Resistance : 6 mOhm, now they heve 3,5mOhm [img]i/expressions/face-icon-small-smile.gif[/img] That really makes a difference. They do it so i want to learn it to and don't say it isn't possible because IT IS.
Banned
They manufacture low resistance (high current) cells. But the difference is made in the construction of the cells. The only way to change the resistance of a battery is to rip it apart, and remanufacure it. (or essentially fry the cell, which means you might get a couple of uses afterward, but then its ruined.)
