Rudder on takeoff help
CA
RE: Rudder on takeoff help
Just to add to what grey beard posted: he is correct in stating that adding up elevator will increase tail wheel contact allowing for better control. I have found that with many of my WWI and WWII tail draggers that I hold in up elevator just long enough to get the plane tracking straight, then I feed in down elevator to get the tail up, which lets the rudder kick in with the added tail wash from the prop.
Figured out why I had so little control on take off, I had the low rate set on the rudder, and switched it to high rates. I was tending to over correct on takeoff because it didn't react right away, so last night after I switched to high rate, the take off was SOO much better. A touch of rudder, like I am used to on the Kadet, was all it took to keep it straight. It's not that I didn't know how to take off, I was doing it right all along, just didn't have enough rudder control! Learn something new every time. Like what the hell was that that fell off the plane??<div>
</div><div>A wheel pant came off towards the end of the flight, now its somewhere out in the corn field. </div>
#31
Most of mine are on the shelf over my workbench. If Ifly a model and the pants cause grief in the grass they go onto that shelf. Right now there are four sets of pants side-by-side there. Ihaven't figured out why some work OK on .40 size models but then those on a 1.20 or even 1.80 size model with 4" tires won't track well.
But then Isee the wheel pants for the full-size Cessna 195 at our airfield stay in the hanger; so Idon't feel so bad.
