Dual rates
Dual rates
I have an Easy 2 Trainer and a Futaba T6J transmitter that I can set dual rates on. My problem is where do I start with the low setting? 50% of full? Would this value be the same for Aileron Elev and Rudder??
If your transmitter allows for exponential you may be better off dialling in 30% or more and forget about dual rates. That way you still have maximum resolution and can still get full control if you need it while having a soft response on the sticks when near neutral. Just remember, when dialling in expo on Futaba or Tactic radios, use negative expo, if Spectrum use positive.
My Feedback: (18)
PA
Denny
