RADIO confusion
Hi,
I am looking for a Radio system for myself that I will be able to use for all of the planes that I end up doing. I am also worrying about frequencies. I would love something that can change frequency if there is such a thing... ok so anyways im really confused. THANKS!
I am using the Futaba 9C, worth the money you spend initally to get one. I believe that you can buy a Synthesized module for it in the States. In Canada it is Illegal, but the synthesized module should allow you to change frequencies.
Other than that, why don't you just buy your radio first, then just buy all your recievers and use all that same channel(You can change crystals in a reciever). Its alot less confusing.
but wont just getting like a static chanel radio suck, because if someone else happens to use that channel.... yea. and what do crystals do?
crystals are what makes the channel change. Like on your reciever they can be interchangeable to swithc channels. I would like to say the FCC doesn't alow, but i am not completely sure
You can change channels but I think if your receiver is low band then stick with low band channels you cant switch from high band to low band I belive thats illigal. As long as you stick with low band crystals then you are fine, I think thats only with a futaba radio that has low and hi band, I dont think you have to worry with anything else. I am not 100% sure, someone here will know more than I do.
Check out the Hitec Optic6, when used with their Spectra module, it is just what you asked for. It allows you to just dial in any of the authorized RC aircraft channels used in the USA in the 72MHZ range. Also, to clarify the comment made above, in the USA it is not allowed for just anyone to change transmitter frequencies by changing crystals (doing it with the synthesized modules is legal) without having the output checked by an authorized technician or lab to insure that your change does not splatter outside the allowable bands. This can happen when you just change crystals as no two crystals are exactly alike even if marked for the same frequency and must be fine tuned to prevent spurious radiation patterns that might adversely effect those other users sandwiched in between our bands.
CA
ORIGINAL: wildwobby
ok, why would it be illegal?
You can, however, use a synthesizer module to change channels, (as they more-or-less ensure accurate frequencies that don't bleed over) and you can also change the crystal on a transmitter provided you send it back to the manufacturer so they can fine tune it.
All this only applies to the States.
-David C.
o well, I guess i will just stick with a Futaba 7 chanel and hope no one else picks the chanel I do where ever i fly...
but dont get me wrong im still confused.... i will be able to use the transmitter with other planes and stuff i decide to make R/C too right... It would be great if there were a little guide.
![](/forum/images/badges/trading_plus_member.png)
Geez, just check out the Tracker II (or Tracker III, available this summer) from Polk's Hobby
http://www.polkshobby.com
With this radio, you can save in memory the settings (including frequency) for 99 models, you can synthesize any 72MHz channel, their receiver will adjust to the frequency being used, and it will operate anything you'll be using up to 8 channels. Programs easy, too.
This radio can be used as a scanner, because it checks the frequency before it starts transmitting. If the frequency is busy... it won't transmit. You can travel to a fly-in and be confident of no frequency interference, because you can change your Polk's receiver to any frequency selected on your transmitter - with ease.
I have the Tracker II, and as soon as the Tracker III is delivered, mine will be on the way.
Good luck,
Dave Olson
Good luck,
Dave Olson
My Feedback: (10)
PA
go to the futaba website at www.futaba-rc.com and check out the manual for the 7c . it has 10 model memery so you can fly up to ten helis or airplanes. also if someone else is on your channel you just have to share thats all. a flight usually last 12 mins or so and when they land and shut their radio off and the channel pin is returned and cleared you can get the channel pin from the frecuency control system and go fly. or if your at a small field just make sure the other guy isn't flying or has his radio on when you go to fly
PA
ORIGINAL: wildwobby
...i will be able to use the transmitter with other planes and stuff i decide to make R/C too right...
I'd stick with Futaba too... those Tracker radios look like some high-school kid's science fair project!
![Smile](https://www.rcuniverse.com/forum/images/smilies/smile.gif)
![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
![Wink](https://www.rcuniverse.com/forum/images/smilies/wink.gif)
so if i go with this...
http://www2.towerhobbies.com/cgi-bin...=LXHKS5**&P=ML
I can change channels only if i buy a module for that chanel? and what channels can I use for things that i just decide to make that will stay on the ground?
TX
There are now 72 mhz channels that are legal to operate ground RC, or anything other than aircraft. That is why they are labeled "aircraft use only." The biggest reason is if you're driving your RC car around somewhere, and someone is trying to fly a plane on the same channel, within range of you, you'll screw them up. You have to get another transmitter all together for use in ground RC.
If you use the modules to change channels on that 9 ca, then you're receiver will also have to have the same frequency crystal installed for it to work. That means if you buy three different channel modules for the radio, then you'll need those three crystals for your receivers. You can buy receviers from just about any hobby shop, or online retailer. They come separately, or in flight packs (with servos and battery). You can get futaba, or hitec recevers to work with that radio. however, if you're strongly considering buying different channel modules for it, then you need to stick with all the same brand of receiver, I'd just stick with futaba. Why? That way you don't have to have but one of each crystal. Pick your channel, pop that crystal in the plane you want to fly, and go fly. Hitec crystals will not work in futaba receivers, and vice versa.
I have a cheaper suggestion for you. Go to your field, and pick a channel that no one, or few people use. Then, just stick with that channel. The VAST MAJORITY of sport pilots only need one channel. You're fixing to spend big bucks on something that you probably don't even need.
ok, yeah your right i will just use my lucky number 36 for the channel. But how do i get other receivers to work with the same transmiter on CH 36
My Feedback: (32)
NY
I have been told that it does not matter if your Futaba receiver is high or low band, I am currently flying a low band receiver with a high band (46) crystal and have had no problems at all.
My Feedback: (12)
ORIGINAL: wildwobby
My Feedback: (32)
NY
you can change the crystal in the receiver very easily. Look at it and you will see a tag sticking out on one side with a Number. That is the current channel you are on, simply replace that crystal by pulling it out , and replace it with another crystal with the channel of your choice
![](/forum/images/badges/premium_vendor.png)
ORIGINAL: wildwobby
also... say i wanted another plane. How do i get another receiver? thanks
If you want another receiver, you buy another receiver. I have 11.
ORIGINAL: wildwobby
You asked for a little guide. Here it is.
Radio Systems Part 1 - Standard Radios
http://www.rcezine.com/cms/article.php?cat=&id=44
Radio Systems Part 2 - Computer Radios - A Better Investment
http://www.rcezine.com/cms/article.php?cat=&id=65
The Radio - The Pilots Cockpit
http://www.rcezine.com/cms/article.php?cat=&id=59
My Feedback: (12)
ORIGINAL: JPal101
TX
How do we know what you have. You've only told us what you wanted to buy. Radio basics are the same (as far as frequencies and such) regardless of how many channels your radio has.
Might I ask how old you are?
would the unfortunate more expensive combo of
http://www2.towerhobbies.com/cgi-bin...?&I=LXAKN1&P=7
http://www2.towerhobbies.com/cgi-bin...I=LXBFK036&P=7
WORK? with my 36 channel 9CAFS?
