Squewd wing...
ON, CANADA
OK I had a previous post about the trailing edge, but after holding it bowed in the opposite direction it is about straight. The problem is that still the aileron is not straight with the TE (about 1-2cm), and I've used a straight rule on the TE the LE the main spars and even the ribs once all built up with just the TE missing and lastly the aileron, all individually they are straight but when I put it all together something goes really funny and the things just will not go straight, I hope to be receiving new TE's and main spars from Great planes as I thought those where the problem before I straightened the TE. The ribs also when piled and using a angle to keep them straight are all about the same (off by max of 1mm) so if anyone has any ideas about this or has built the PT-60 trainer and can give me some pointers it be great cause now I'm all out of ideas.
Dave
Dave
ON, CANADA
no hinges in yet, the PT-60 wing is a snap together u glue last so I was just checking everything before I even looked at the glue and luck I did but now I'm so stumped as what could be wrong, unless... just thinking about it now the grooves in the ribs are off but the outline is the same, but I'm sure I checked that, well something else to look at. But please any more suggestions would be great as I think my last idea wont solve it.
Dave
Dave
