Control horn and adjusting elevator throw
TX
I finished a Venture 60 kit over the weekend, but I have a issue with the elevator throw and control horn.
When adjusting the elevator throw (I think the manual suggests 5/8 inch up and down), I had to put the clevis from the push rod to the very bottom control horn hole (the hole closest to the elevator) in order to achieve the 5/8 inch. Is this normal or what did do you think I may have done wrong? It would be nice to have the clevis near the middle in case I want to play around with some more elevator movement. Is there a way to adjust this so the clevis can be place in the center of the control horn and still have 5/8 inch throw? The rudder and ailerons are fine with the clevis located near the top of each control horn.
RE: Control horn and adjusting elevator throw
I try to adjust my linkages for the greatest mechanical advantage, while still exceeding the recommended throws.
Then I use the transmitter's endpoint adjustments to bring the actual control surface movement within the specified range.
That permits me to later merely "dial it up" once I am comfortable with the plane.
ORIGINAL: agexpert
Get longer servo arms, adjust to the outer holes on the servo arm or run your servos at 150%.
TX
Thanks for the replies.
I looked at my servo arm last night and I can move the push-rod out one more hole (it's currently in the middle). I'll have to check to see how much more throw that gives me, but I think it should help.
If that isn't enough try increasing your endpoints or longer servo arms
http://www2.towerhobbies.com/cgi-bin...&I=LXD668&P=SM
Jr or Airtronics versions also available. Don't go too long as it starts to load down the servo and it's gears.
