buckled ca hinge
NY
buckled ca hinge
After installing ca hinges for the first time I noticed one buckled, I did not notice this until after I glued all the hinges it was NOT very noticeable! the hinge look correct. I put the hinges on the wing first with a pin in the center then pushed the aileron on the hinges this must be when one buckled looked like a “z†bend between aileron and wing something for new builders to be aware of.
RE: buckled ca hinge
ORIGINAL: wzak29
the slot was correct I used a electric slot cutter
NY
It’s the 3rd one from the wing center (second in from the tip) the rest are fine. I wish someone tolled me to watch for this I read everything I could find about installing ca hinges and there was nothing about this?
OH
ORIGINAL: wzak29
As far as telling you about this. Good luck with getting all the information. The great hobby is nothing but learning. Good luck with your hinge.
RCU Forum Manager/Admin
My Feedback: (9)
If the rest of the hinges are already in place you've only got two choices. 1) live with it like this, or 2) cut all the hinges, reslot for new hinges, and install new hinges. Like Minn said, I doubt that it will make a big difference.
For future reference, even with the electric hinge slot cutter it's best to still check each slot before installing the hinges. See if the hinge can slide into the slot. If not, use a hobby knive (X-Acto) to clean the slot out.
Ken
Ken
Since you have a slot cutter rehinging is not that difficult either. ( assuming it's electric ).
Carefully cut the existing hinges to separate the control surface.
Cut off any remaining hinge material. I also will use a drum sander to make the remaining material flush with the wood or covering.
Now you have to make a choice.
You can carefully try to cut new slots immediately above the existing hinges. The offset will be so small that it will not matter.
Ideally you would cut the existing material out, but this is almost impossible. Just manually scribe a small line or depression where the slot cutter will begin cutting, and then use that as a guide.
OR you could slot new hinges adjacent to the area they are currently in.
Normally I do the former for looks.
That's it.
That's it.
opjose
When you rehinge in the same slot, isn't the balsa already soaked with CA and maybe not get a good bond or pentration. I haven't done it, so I only posing a question.
The electric slot cutter does a fairly good job of removing just enough material that this is not a problem.
If you can do this right up against the existing hing, if anything the area is a bit stronger due to the bond to the hinge and the other side that is already hardened.
I will NOT do this with hand picks however. I tried once and I could never get good results attempting to remove the adjacent area.
The Electric slot cutter solves that.
Of course to REALLY play it safe you could pin the hinges too.
MA
ORIGINAL: goirish
opjose
opjose
ORIGINAL: shd3920
Correct. Do NOT rehinge next to the old hinges, the CA soaked wood will not absorb sufficent CA to hold the new hinges. Rehinge in different locations.
I guess we will see when it gets into the air and I start pounding the body with the 60 engine, but as far as I can tell, also got a second and third opinion from more experienced, it fits perfectly.
