Machining engines?
Ok i have been posting alot. But i am new to nitro and i am very excited. as most of u were. My friend owns a machine shop and he siad he could copy my engine. He likes to tell lies a lil. I know he has the machine shop and all but is there away to do this. And also would i be able to make my own engines then? He siad he could make them outa titanium. Would this be a good thing. Has anyone tried this.
WA
Your best bet would be to stay away from making your own engines. he may be able to copy it looks wise, but the performance would just plain suck. Nitro engines are made out of certain materials for a reason.
I make all my engines myself.I use titanium as well and the engines are impossible to wear out. go for it and let me know how it turns out for you.
1 Post
ORIGINAL: asmund
I'm sure everyone here would love to see some photos of your engines.
oh yeah I bet . I use titanium for the crankcase, crank and head,and kryptonite for the piston and con rod(very durable) the carb I make out of aluminum and some brass.The most time consuming is to make the bearings. I make them out of a lump of ceramic and burn them myself in a oven. they turn out great.I say go ahead and do your own engines, its not at all difficult and well worth the time you have to put in it. Afterall a new engine can cost as much as 120 bucks.
VA
Tell him to go for it... seriously.
The materials are nothing special.
Use 7075 Alu for the rod.
High silicone Alu for piston
The liner is brass with a chrome in the bore. It needs to be tapered slightly. No clue about how much.
The case is cast Alu but just have him machine it from 6061 or 7075 Alu.
Hardened steel for the crank and wrist pin.
He can probably do it but it will take time to get it right.
SK, CANADA
Ok for all you non informed on machining equipment a low precision mill or lathe is accurate to around 1/10000 of an an inch and a high precision one is around 1/100000 to put this in persepective an average human hair is only 4/10000 of an inch in thickness so no you dont need a "high precision" mill or lathe to make parts my dad makes me parts all the time (career machinist 25+ years) I'm starting to learn how but im not to good with mill yet but it really isnt that difficult if you have some teach you who knows what there doing and has the time.
IA
Why not use the internal parts from an existing engine and just make the case. Custom engine case ( engrave your name, turn a side exhaust sleeve 90 degrees and have a rear exhaust, change mounting hole dimensions, water cooling.) the possibilities are endless. People who tell you that it can't be done are narrow minded naysayers, go for it.
IA
Take a look at the marine engines for boats, just a cooling head with a water passage. In a car you would need a radiator and a pump to cool and circulate the water, probably not worth the trouble.
ORIGINAL: asmund
Titanium isn't as good as unobtainium although it is cheaper and easier to machine.I've had the best results using it rather than titanium but it does require a 4 axis mill with a top speed in excess of 30,000rpm to get the best results from the diamond cutting tools.I make the head out of high temperature glass so I can see if the fuel's igniting okay,takes all the guess work out of finding the right mixture.
Pistons should me made from magnetic iron so that any stray metal particles stick to it and don't float about inside causing the bearings to break down.
Best fuel is 98% nitrmethane with 1%oil and 1% nitro benzine or turps if no nitro benzine available,my engines easily exceed 60,000rpm and last for over 30 gallons of fuel.
I'd post a pic,but the next doors dog buried the engine somewhere and he won't tell me where,even though I've tried to bribe him with a jam sandwich.
![](/forum/images/badges/premium_member.png)
ON, CANADA
ORIGINAL: bikeracer
EDIT: I LOVE THIS PART
----"Finding the correct needle setting requires running the engine at speed with a load. You will never achieve complete combustion, so what colour of the rainbow are you looking for?"--------
Well it varies between a darkish black and a lightish white,depends on which specs I'm wearing at the time.
-------"If you prove to me your engine spins 60 000RPM and runs on 1% oil for over 30 gallons, I will buy your engine for $30 000 US Dollars...... Better yet, just the 60 000RPM"--------
I can't prove anything now that that damn dog buried it,further bad news is that he's just been taken to the vet and it's unlikely he'll be coming back.I'll miss him because he was good at sweeping up and making tea.
I wish I could sell it to you as it would make me a tidy profit of $29.997.99 and I need another batch of unobtanium and there's a world shortage at the moment with all stocks kept in Beirut,plus the glass blowers are on strike.
ON, CANADA
First of all, the frequencies caused by the engine combustion would break the glass. If your fuel had Nitrobenzine in it, I would like to know where you get it. Read this, about a 1/3 of the way down it say this... Nitrobenzine(Oil of Mirbane) Yellow oil in some perfumes and dyes. It reacts with the blood and corrupts it, and also paralyzes the central nervous system. Initial symptoms: burning sensation then numbness in mouth. Pallor. Unconsiousness. Death within about 2 hours by respiratory failure. Post-mortem appearance: Cyanosis - greyness at extremities. Blood dark and thick. Stomach has a red congestion and bleeding under the surface. Organs smell of bitter almonds, like with cyanide.
http://www.keleka.net/deepbackground...cs/toxicol.htm
Respiratory failure, do you know what that means? You inhale it, you are dead in 2 hours.
Another dumb comment, Unobtanium is a word that describes a metal characteristics that are impossible. We use that term in the engineering world all the time. It also sounds alot like Unobtainable.
As well, a 4 axis mill? Why am I wasting my time trying to argue with you.
Anyway, lets all wait for the silly rebuttal.
