Cen Gst 7.7 arrived and i have pics and more ???
My Feedback: (7)
NJ
Ok guys friday after my last class i returned to my dorm to find a Huge box in my kitchen to my surprise i started to open it and i found this Huge truck bigger than what i had pictured
Its way bigger than my LST2 Is it faster??? im not sure but ill see tomorrow
Heres the ARCBOYZ collection, well part of it atleast.
Ok so more questions, i bought the ofna valve, i started to break it in on friday afternoon i idled 3 tanks, it kept on shutting off now i think that its too rich should i tune it? im down to 4 tanks, i did one running and swaying at the curbs kind of in a oval shape. also i plan on doing two more tanks, tomorrow and finally let it rip on the field ( 3 baseball fields put together) it also shuts off so should i tune it? what can i do about the steering? bigger steering servo? also what are the needle default settings?
thanks, alot arcboyz
CA
RE: Cen Gst 7.7 arrived and i have pics and more ???
If you already idled through a few tanks I would start to drive it and lean it about 1 hour after every tank. My Genesis wouldn't idle long during break-in either. The heat cycle method is a better break in procedure.
As far as steering servos go, I use a Hitec 5955TG ( 333 oz/in of torque)
