Lasercut USA Blue Angel Build
![](/forum/images/badges/trading_plus_member.png)
My Feedback: (17)
Hi All,This is the start of the Blue Angel build this build is going to use the original MK BA plans, as some of you might already know Lasercut USA and RCAIIR has teamed up. RCAIIR will be offering and distributing Classic Pattern Planes Full Wood Kits cut by Lasercut USA soon, of may of the popular CPP. Well here we go. I started the Stab first it is pretty much straight forward,as you can see you use the original MK plans to build from
Pat
LCUSA
Pat
LCUSA
My Feedback: (17)
Hi Will ,YES this is just an add on of the things i do every day if you know were i can get a set of plans for the Wild Beat i should be able to make a wood kit from them
Pat
LCK USA
Pat
LCK USA
My Feedback: (17)
Started the wing pretty straight forward, build over original plans i made one change i used 1/8 birch plywood for the retract ribs with 1/8 birch plywood dblr.
Pat
Pat
I have the Wild Beat kit (mostly complete, I need to get back to it someday). Of course I have the plans.
Hi Pat,
could you take on another laser cutting project for wings and stabs of new plane design? If yes, I can put the principals involved in touch with you.
thanks
thanks
I sent sent you an email.
I can't open .dwg files so I'm not certain that the ribs and crutch stations are in the attachments. The PDFs are there only as building aids after the ribs have been cut serving no real purpose for you.
I got another set of attachments from the designer which are supposed to be a complete file set
Of the wing and stab ribs and the spars that require laser cutting. I will send that to you shortly.
lets take this off the forum and communicate directly please
My Feedback: (17)
Need Help, I can not seem to find a fuel tank that will fit in the BA, anybody know what type will fit in there it is pretty small opening with the motor mount rails in place did MK make there own fuel tanks ???
Pat
LCK
Pat
LCK
![](/forum/images/badges/premium_member.png)
I'm waiting until Pat ships me the parts he cuts for me and I add all the blocks, sticks, sheeting, canopy, fiberglass chin cowl, fiberglass pipe exit molded piece, and plan. Then I see what my cost is and post them on my monthly list.
