blade cp pro problems
hi I got a blade cp pro extremely chep and knew it would have issues but my main issues is the blades will spin but will not spinwith enough force to lift the heli off even tho they are spinning pretty fast anyone had this issue and how can I correct it. I assume motor which is my first thought
RE: blade cp pro problems
First thing to check as you guesseed is the motor.
These things have cheapo brushed motors and they frequentley die.
If you happen to have a can of 'contact cleaner' you can spray this in the motor which might give it some more life, or it might just be done.
They are very cheap, so get a new motor and try it.
IA
Best fix is to junk the heli had one been there done that. They are crap and never flew worth a darn. Tried every thing brushless main motor tail never would hold better gyro still crap. Not a good heli Have a MCPX BL Nano Love it flys 300 times better than the cp pro which is outdated and never was worth having for the price.
