Axi 2204/54 squeal
![](/forum/images/badges/trading_plus_member.png)
IL
What timing should be programmed for the Pheonix 10 esc and AXI 2204/54 outrunner motors on 2 cell lithium packs? We have a soft start, no brake, 5.1 cutoff, and normal advance settings.
A group of us just bought 7 such combos and have been experiencing a loud screaming sound coming from the motors up through about 1/3 throttle.
The first motor doesn't make the noise any longer, but was noticably noise during the first 4 battery packs. We initially just thought these motors had a different sound than the larger Axi motors. We are wondering if this is a timing issue, a motor break-in process, or something else.
Two more power systems are showing the same symptoms now.
I have purchased the Pheonix Link programmer and downloaded the latest software.
Tyler
ON, CANADA
I have same combination of setting and I did not have any problem.
![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
Ziv
![Smile](https://www.rcuniverse.com/forum/images/smilies/smile.gif)
This happened to all my AXI's when I updated to Version 1.161 software. I went back through all versions to Version 1.14 (which is what I started with) and all was good again...
I havnt tried Version 1.22 yet, maybe I'll give it a go tomorrow. I meant to try different timing settings to see if that fix's it, but havnt had enough time yet. Version 1.14 works great for the moment.
GA
Yep...it is the software version......
I called CC and they were helpful...
go back one version of the software
(1.14) it will disappear......
I have not tried the new version yet (1.22) didn't even know it was out there
