identify this plane
AZ
identify this plane
i was wondering if anyone could tell which plane this is or something similar. it seems to be made out of a plastic almost... i see a cheap kit similar to this at like every hobby shop i go to. [link]http://www.youtube.com/watch?v=0ul_5DtMLhc[/link]
RE: identify this plane
That is a "GWS Pico stick F" (f stands for full fuselage model)
It is a 3ch foam plane that uses an GWS IPS motor system,a 2s lipo,2 servos, an RX and 10A ESC,simple,flies great.
AZ
thanks i was looking for the regular version of this without the fuselage. i already have an fm radio and a 700mah 2s lipo with charger from my heli. all i need now if i get the plane is 2 servos, a motor and a receiver
Personally, I get the larger slow-stick,it likes small batteries and is easier to fly,don't forget an "GWS ESC480li" ESC,that is the best for either.
AZ
i found a cheap brushless set for 15 dollars. im getting it so i can use my lipo with it. i also found some servos with good rreviews for 4 dollars each. im going to get the 46" version of this. anything i should know? replacement parts to order?
Seriously,get the slow stick or a different motor,I know hobbycity.com,you bought the towerpro set up,it is way too much power for that plane,the plane weighs 8 oz and you are going to put a motor that outputs 22 oz of thrust,that is way too much,it will rip the wings off.
CA
Sonic, I was being a bit F for facetious. The plane does look like a fokker however.
Yahman, I flew my fokker with a tp 2410-08 and 10x47 prop, but if that combo comes with a Mag 8 esc, it is probably only good for 3s lipo.
Tim
Tim
