22x13 Electric prop
ORIGINAL: Walt Thyng
I'm hearing good things about Xoar props. Haven't used them personally yet, though.
Walt
Walt
But where do I get one of those in Europe?
Keep in mind that the Xoar props are wood and wood compresses with time. So you will need to stay on top of making sure they are tight if your motor adapter works with compression. Composites like Mejzlik and APC do not compress so are less likely to loosen with time.
ORIGINAL: Silent-AV8R
I could off course use a 21x14 but I prefer the large disc, better braking better pull.
Engel would be my #1 choice for electric. But they don`t have 22x13. They have 22x12 and 22x14. They are easy to run, if you aim for 22x13 I guess 23x12 could be used... Check: http://www.engelmt.de/en/top.php
