power supplies
![](/forum/images/badges/trading_plus_member.png)
My Feedback: (26)
I've been running the 42A supply from feathermerchant. They're used server supplies and are compact and quiet.
http://www.feathermerchantrc.com/
Well spotted Rendegade it is designed for storing LP's, looked for an appropriate box for ages but couldn't find one the right size. This one came from Jaycar, I picked up the last two they had. Why you would want a camouflaged LP container I don't know. Lucky all my LP's have been converted to MP3 now!
Simon
Simon
Yep. Case, PSU, extra plugs, internal stand offs and fan covers all from Jaycar. Fans from a PC supplier and wire from Hobby City. I'm now building a second one for one of the guys. Neat solution as I can fit four 10S packs in the end section and charge them by just switching the wires across. Put the lid on and everything is neat and tidy in one box.
#34
Hi Joe,
I have never seen the Iota PSU but it looks like it has at least one connector for the 13.6v output. I would connect the biggest wire you can (say 10AWG) from there into a pair of banana plugs or use a power strip unit as seen on p1 of this thread. You then plug in your chargers to the output of whichever you have installed, this way the components remain stand alone and you can always take out any that have a problem or you want to use in another application.
Just make sure that everything is well ventilated so things remain cool, I note that the Cellpro chargers get quite hot when they are charging 10 cells at 5 amps (up to 210W). If I am charging at home I leave my charge box in the middle of my garage concrete floor (ie. non-combustable) in the event that a battery goes pear-shaped. The only other mod I think is needed is to put batteries being charged into a lipo sack to decrease the risk of something going seriously wrong.
All the best, Simon
All the best, Simon
#35
MI
Hi Joe,
I leave the plug in mine. It's been working fine that way for 3 seasons.
Verne
Verne
ORIGINAL: gaRCfield
Took a while, but I just got my Iota DLS-55 today.
Do you guys just keep in the plug for 14V operation?
Any creative ideas for connecting chargers?
I'll work on a box over the winter.
#36
Thanks Verne!
Charged my first set of batteries at home last night - boy is it nice to not use my truck battery!!! That got old, fast.
I am mounting the PS in one of those metal cases from the home supply stores. Fits the PS and 3 chargers. Found a (bus?) at Radioshack for $3 that I'm using to distribute the power (8 ports, 2x4 bridged, made for high voltage applications). Everything will eventually get mounted (velcro?) and joined with Anderson Powerpoles for easy removal and system changes. Should be able to unplug PS and plug in cables for using at the field, until I get my generator.
Will upload pics when I get things together.
Thanks for all the help.
#37
My Feedback: (71)
I will be building this boxes for sale for $200.00 with 50 amp power supply or $125 with out power supply plus shipping. The Box will include fans on the side of the box Plexiglas top to mount you chargers and power input in the side and banana plug output in the top for connect you charger.Also I can get the box in different colors like blue,yellow,black,red,pink,silver and diamond. Contact me at 678-799-0518 or [email protected]
#39
My Feedback: (16)
TX
ORIGINAL: StikDude
Where do you guys get your banana plug female outlets? The one radio shack carries are only listed as 10A max.
