Projeti
Projeti
Hi, I'm almost done with my Projeti.
Little about the spec.
Mega 16/15/3 with 8X1200 cells (and one pack 8X1900 Cells)
The weight will be around 700 grams. With the powerful batteri pack. Two HS-55 servos and a HS-555 for receiver.
Is this good enough spec for the plane?
But my question is, how hard/difficult is it to fly this plane?
Little about my skill in airplanes:
I'm not a beginner anymore, well the case is that i haven't been flying much the last two years, only sail-flying with my electric sailplane. Before that (more than 2 years ago) I flew almost everything, so I'm past the "trainee" stage.
But still I'm not quite sure i will be mastering this plane when i take the maiden voyage.
I have search trough the forum, to find similar question but i didn't so then i ask if anyone here could help me.
Will be able to master it? (by your experience with projeti)
Is there anything i should be aware of?
Any experience you have would be nice, and what you think i need to make sure of before and under flight.
Thanks in advance for any replies.
Cheers.
Thomas.
Cheers.
Thomas.
Projeti
Here is a couple links to some reviews:
http://rcgroups.com/links/index.php?...at=198&id=3911
http://www.rcuniverse.com/reviews.ph...iew&reviewid=1
Also take a look on this page for some video's so that you can see what your in for. One suggestion will be to keep it real light for the first flights to make the launch and landings slower.
- Bill
- Bill
