Grr...Astro 020 Twitching
I went out and flew my zagi with astro 020 today, and toward the end of my flight, my motor quit. I figured it was just BEC, so i brought it in. I put in another battery and then fired up the engine. All I got was some twitching. This happened earlier, like 2 days after i bought the thing, and it turned out that one of my three wires was broken. I got rid of their little connector, and put on my own splices for the 3 motor wires. This time I get twitching, and my ESC gets really warm also. I dont notice any of the wires broken this time. Could this be that i blew my ESC? Has anyone taken an astro 020 apart? I'd like to go in there and put some decent input wires to the motor either way.
Thank you.
-Dan
Thank you.
-Dan
GA
RE: Grr...Astro 020 Twitching
I'll bet it is the ESC.
Is it he one that came from Astro or is it a real Phoenix 25 from Castle. Castle makes the Astro controler but it is not a full fledged Phoenix 25.
GA
Must be the Castle then.
I can look it up but need your last name as I don't know the cinntax handle. I have not stocked the stock Astro controlers for a while but am happy to help you with it if it is acting up.
Are you using the stock battery? 400X or XS?
Cliff-
It's almost like we're chatting!
Anyway, my last name is Cinnamon.
I bought it around early December 2003.
I'm using the Stock 400X pack.
I was suspecting wires because when I was having the same problem earlier, it was a wire that broke off from that connector that comes on the motor. When i removed the connector, I could move the insulation around on the three wires. It kinda makes me feel like astro didnt put very quality wires on their motor. I was hoping to replace the wires with some really good wire i have.
-Dan
-Dan
GA
Found you in my system Dan:-)
Yes it could be shorting out on the motor housing or just inside, I have seen one do that before. You can send it directly to Bob at Astro (or to me and I will send it to them for you) and they will replace the wires and do a general checkout of the whole motor. I have never seen a repair over $25 and sometimes it even comes back with a new controller if it is bad ;-)
13311 Beach Ave.
Marina Del Rey, CA 90292
13311 Beach Ave.
