Futaba T8J not binding with R2008SB
Hello
I am using Futaba T8J transmitter and R2008SB receiver.
Recently T8J stopped binding with r2008sb. Tried Re-binding as per manual but didn't work as the red light kept blinking without binding. But when the receiver is powered, the LED is solid red.
Also, the output display symbol (Tx symbol) on the LCD screen is missing.
Any solution to this issue will be appreciated.
Thank you.
Thank you.
Make sure batteries are fully charged
Get the RX and TX antennas as close as possible, touching is ok
Hold the LINK button on the RX down for several seconds, the LED will blink red, then release.
Blinking green means the RX sees a signal, but is not linked
Soild red means the RX is not seeing a signal from any transmitter
If LED on RX remains red then the fault is likely in the transmitter. I suggest sending it in to your nearest service location if the above does not work.
Service center details
I am from Goa, India.
I am USA based and I do not know where a customer from your country would need to send for service. Perhaps contact the company you purchased the radio at and they might be able to help you out on where to send for service. I will also see if I can find the information you need.
