R7208SB in dual redundancy rx mode
Thinking of buying an R7208SB to benefit from the dual RX.
If i attach another FASSEST receiver to an R7208SB and combine them as dual RXs , is it only the R7208SB RX's standard servo outputs that are controlled from either receiver depending on which it chooses? Am i right in thinking that the "other" receiver outputs are only fed from its own receiver circuit (not both RX's)?
Im thinking i would have flight controls on the R7208SB as channels 1-8 (mode A) as these would have 2 receivers feeding them and i would have ch 9 upwards on the "other Receiver" with less vital servos not benefiting from 2 receivers.
16SZ transmitter & no Sbus servos!
DaveM
DaveM
Dave, when i played with this system for testing, i found it to be the most crazy version that Futaba has ever come up with.
The idea is for dual receiver redundancy, with rx 2 as the back up.
All servo connections are made only in rx 1.
But when I questioned how can i demonstrate that rx 2 has taken over from rx 1, as there is no visual identification of this process ?
The answer that came back from Japan was - "simple, just cut off the antennas from rx 1 and rx 2 will take over".
This is NOT the way to do redundant receivers !
modtron
Oxford UK
modtron
Oxford UK
Thanks for the replies. Decided against buying one. They would be better selling an add on rx (with no servo slots) that gives extra redundancy to existing receivers.
Thought about metal plates to "hide" the antennae to test the system but decided to stick with my 14ch rx
Cheers Dave
Cheers Dave
