Futaba T16IZ servo speed changes
My Feedback: (32)
FL
I have programmed a flap to elevator mix on my Futaba T16IZ transmitter. I want the flaps to come down slow and go up fast. I can make changes under the servo speed menu, but keep both directions at the same speed. Is there a way to change this?
I used other transmitters where this feature is available.
Would appreciate the help on making this happen.
Thank You!
Thank You!
Go to AFR for your flaps on page 2 you will see at the bottom of the screen speed in and out change the numbers to suit.
0 is normal 27 is very slow page 213 of the manual
