8 U Rudder pot
My Feedback: (7)
I have had two rudder pots replaced in my 8 U TX and now I have the problem ag. ain. If you move the throtal stick straight up and down the rudder jumps to one side bad . I know I am not cross sticken it. I can use my 7 ch Futaba with the same module and it don.t do it. Is there something else in the programming that could cause this? I have tride a different model no on the 8 U and it still does it . Thanks Rich
![](/forum/images/badges/trading_plus_member.png)
Hi Rich,
My first suggestion would be to go into a blank model and see if you have the same problem with the rudder when you move the throttle stick. If you do not, then yes, it is something in the programming, if you do have the same problem then it sounds like the pots are the problem again.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://www.futaba-rc.com)
Sincerely,
Krysta
My Feedback: (7)
Kyrsta Thanks for the responce. I did call the tech line and there is something frying the rudder pot . I will send it in to get fixed. Thanks Rich
