Zenoah g26 carb replacement
Hello I want a replacement carburetor fro a airplane zenoah g26EI. I can´t find the wt-645 but I can get a WT-834-1 or a WT-929 carburetors. Will any of them work with this engine?
Thank you
Thank you
![](/forum/images/badges/premium_vendor.png)
My Feedback: (16)
The definitive replacement carb is the WT-813 as it has a accelerator pump. It is the same size as the original. This carb does not have a choke.
WT 677
WT-643
WT-644
WT-645
WT-257
These are a size smaller and were on the G-23 but you will like them
WA-167
WT-499
WT-197
WT-647
WT 677
WT-643
WT-644
WT-645
WT-257
WA-167
WT-499
WT-197
WT-647
Ok I am looking to the 813, but I have three questions:
-Can I take the primer bulb and swap it with the plate of the 645?
-If not, Can I run the engine with the bulb in a cowled (with no access to the carb) airplane? (BTW what is the bulb for?)
-How can I choke the engine if it has no choke? Can it be done closing the throttle butterfly?
Thank you
Thank you
DC
Primer bulb carbs have an extra hole in the fuel chamber, you can't just put a primer bulb on a carb that wasn't designed for one..If you put a flat plate on a primer bulb the hole has to be plugged...I tap the hole and put a 2-56 screw in it and cut it flush..
The primer bulb is there to draw fuel into the carb from the tank, the extra hole and fitting returns excess fuel to the tank from the extra carb fitting when the chamber is filled....
The choke completely closes the venturi, theoretically closing the throttle completely should do the same thing,,,
Excuse me, but I don´t get it fully.
I have three lines in my fuel tank, one to the carburetor, other to fill it and the vent line. How is the return line from the primer bulb directed to the tank again?
![](/forum/images/badges/premium_member.png)
Place a Tee in the line from primer to fuel tank. The "T" will give you a way to fill tank & let the fuel flow back to carb from emgine. Capt,n
ORIGINAL: Fulcrum2111
Is the Tee placed in the tank to carb line or in the bulb to tank (return) line?
DC
The return to the tank is for weedeaters, not needed on the airplane...If you use a primer bulb carb the excess fuel will just spill out, you can put a line on it to get the fuel out of the cowl....
Three lines are not necessary, just put a T fitting in the line from the tank to the carb...Plug it after fueling....K I S S principle....
![Wink](https://www.rcuniverse.com/forum/images/smilies/wink.gif)
