DLE 20 no compression
Hi all I just rebuilt a DLE 20 with new piston, ring and cylinder and it has almost zero compression, I used lots of oil during assembly the ring is in the right orientation , I tried starting it and nothing, it won't even burn a prime. I did something wrong but what?
If you had much in the way of difficulty sliding the piston back into the cylinder on reassembly, the ring was likely broken in the process. It's absolutely critical that the opening in the ring be centered on the locating pin located within the ring land during that process.
There's also a chance you have something going on with your reed valves or the plate that holds them. If there is anything going on there, compression will/can be really wimpy.
I'd pull it back down looking for errors.....
My Feedback: (19)
