Throttle blipping on its own
![](/forum/images/badges/trading_plus_member.png)
My Feedback: (23)
FL
I have a lazy ace with dle 30. All of a sudden the throttle starts to blip on its own at idle. Any ideas? Older 9c with extreme link module and receiver.
![](/forum/images/badges/premium_member.png)
Many possibilities. An easy one to eliminate - bypass the power switch(s) and plug in the battery directly. Fire 'er up, and see if it still misbehaves. I had a bad switch that plagued me through replacement of everything else (plugs, engine, radio, batteries) once...
Do the same with different batteries if it is not the switch.
Did it just start on it's own, or did you make some changes, or took something apart (unplugged the plug wire and put it back, etc.)?
