Tartan Twin info
My Feedback: (9)
CA
Tartan Twin info
I am interested in any info from users of the Tartan Twin. I have spoken to Jim Cline, but would like to hear from anyone using this twin on a regular basis.
Phil
Phil
Tartan Twin
Did you find out more data on the Tartan Twin? I missed a good deal on one at a swap meet. It was a super glow version, if I remember right. Nice looking engine. A little on heavy side for some hot rod planes. Take Care John- from w. Mich
My Feedback: (9)
CA
Tartan Twin info
Thanks for the interest, John. No, I don't suppose anyone is using one currently, or that's what it looks like. I picked up a pretty good one here on RCU with electronic ignition and an updated carb. It looks like it was hardly used. I haven't run it yet, been busy with my other planes and work but I was thinking of a clipped wing T'craft.
My Feedback: (14)
MO
Tartan Twin info
I actually made a four cylinder engine out of two of them - sounds like an Offenhauser.
My Feedback: (19)
VA
Tartan
Well...Out of the box ..these engines are good as a paper weight...BUT if Jim Cline or a gentleman in Florida..whose name leaves me at the moment...massage them a little ..you'll find they scream like a scalded dog,,,Run on methanol and klotz oil...
You may or may not know..but back before planes got the size of your garage..This was the engine of choice for the TOC..and Jim and (blank) were the guys to hotord them for you...
I have one in an Ohio EXTRA ..spins a 19x10 Menz Ultra about
8700-9000..They do not like to lug
My Feedback: (9)
CA
Tartan Twin info
hi Bill
- The gentleman in Florida whose name escapes you is Tom Perry - a Master at massaging these little brutes, and a real gentleman - to deal with!
John
-Sorry, I'm gonna keep it! BUT! DESERT RATT has a friend who sounds like he wants to sell. posted somewhere in this thread.
Phil
John
Phil
My Feedback: (19)
VA
Tartan Twin info
Nope I think this guy is OUSLEY...I'll have to dig in my rolodex...So maybe there is another Tartan guy out there....Mainly ..As I understand it..the port timing is changed by massaging with a die grinder and the reed system is changed to help it breath...
Theres a couple of guys in NC near greensboro who swear by them in Carden Extra 300...It's the reason I got one...ACCELERATED STRAIGHT UP...not just pulled..look like it was shot out of a cannon and kept going
My Feedback: (9)
CA
Tartan Twin
Bill -
You are right! Bob Ousley is the guy! Ed Vollmer E mailed me and set the record straight. Tom Perry has worked over engines for me and my friends and is all that I said of him, an expert and a gentleman. However, he has not worked on my Tartan. What size Carden? Sounds interesting......
Ed -
Thanks for the info. I appreciate the offer , but I think I will see how I like this one first.
Ed -
My Feedback: (14)
MO
Tartan Twin info
Jim Goad (who owned Indy RC and used to sell Tartans) is also knowledgeable on the engine. Last I heard he also transplanted to Florida.
Incidentally, Jim Cline's website for Tartans and Tartan parts is here:
http://www.billsroom.com/pcfs/
Tartan Twin info
I love my tartan twin engine its a glow twin if you need to know anything about them go to billsroom.com mine was hard to start before becauase the carb was upside down but just take a tap and drill a hole just above the carb on the 1/4 inch plate put a presure fitting in it and a peace of fuel line to prime the engine above the reeds and it will start everytime or it will bite you (BEST ENGINE ive ever had.
My Feedback: (9)
CA
Priming nipple
Hi Kevin -
Can you post a picture or sketch on where you installed that priming nipple? My Tartan was converted to gas with ignition and a Large Walbro carb with a big Venturi velocity stack that I reversed to the underside so it would not stick out the top of the cowl.
Phil
Phil
Tartan twin contacts
These guys in NC are friends of mine. One has sold all his Tartan stuff but the other still has all his plus some spares. He has two really nice 30% Carden Extras that are very light & this engine is tuned by Owsley in Florida. On tuned pipes and they really scream - very powerful & best power to weight you can get. These guys are excellent flyers and finished 1-2 in every contest they entered. If you are looking for Tartan advice, I can put you in touch with them.
My Feedback: (8)
LA
RE: Tartan twin contacts
Can anyone give me any information on how or where I can get any manuals on the Tartan Twin 77? Does anyone still work on these engines? Bill Cline from Cline and Associates no longer does any work on Tartan engines. I have 3 of them and I've never run them yet because I'm not sure on the fuel to use or how to set the carbs. They are all glow engines. Any help will be greatly appreciated. Thanks, Mike
I have seen "a" 22cc SuperTartan Manual, and there is not much to it,,
the Manual I had said 5% Oil for Gasoline and 10% Oil for Methane,, I know the Glow Engine was designed to use straight Castor, but Jim Cline said Synthetic is OK, it will take a long Brake-In on Synthetic,,
one thing about them is they don't have the best Reed Valve system, guys are adapting the DL 50 Reed Valve Assemble to them (as I will be doing over the winter), the one guy I talked to that did this conversion said his Engine started better and ran smoother and had better Throttle Response with the DL Reeds,,, the DL 50 Reed Valve Assemble is only about $18 at Towers Hobby,
there are 2 different Cylinder Portings ,,
A) the "Super" has 3 Transfer Ports..
B) the Standard has 2 Transfer Ports
how you tell them apart,, is,, if the Fins on the Top of the Head are 1/2 inch higher than the Glow Plug then it's a Super, if the Glow Plug and Fins are the same height it's a Standard,,
RPM/HP,, the Manuals and Flyers I have read said for Both Gasoline and Methane peak power is 8000, and I did see one Manual that said "Prop for 8300 RPMs" but I don't know how old that Manual was,,
Bisson makes Mufflers for them,,
http://www.bissonmufflers.com/en/muf...mageField.y=10
BTW, if you want to buy a (never run) Super Tartan 22cc with a large Muffler let me know..
Jim
Jim
I may have a owner's manual for the Tartan twin, but I will have to wait unti next week to look for it as I am on vacation right now. I have two of the engines, one is the standard (never ran) and the other is the Super Tartan that was modified by Bob Ousley several years ago. I purchased the first engine used at a hobby shop. I could never get it started and Jim Goad at Indy RC gave me the contact info for Mr. Ousley. I learned from talking to him that the cylinders had been turned over inorder for the carb to be on the bottom for easier in cowl mounting. The engine would not run like that. I turned the cylinders over and it started on the second flip. In talking to Mr. Ousley he told me of the advantage of his modifications so I sent him the engine. When I got it back, boy what a difference. I had the engine on a Lanier 33% Lazer, and it flew it with authority. The only draw back was the fuel consumption on alcohol. Thirty two ounces would only fly about ten minutes. I put a 50 ounce tank in it and would get about 18 minutes. The engine required baffles in the cowl for cooling and was a pain to change the glow plugs. After Mr. Ousley modified the engine it would not hand start anymore and he told me that up front. To start it I used a Miller reduction drive on a Sullivan Dynatro starter on 24 volts which is probably overkill. When I return home I will look for the manual and contact info for Mr. Ousley.
My Feedback: (21)
Great info guys! From looking at the pictures, mine is a super Tartan as well. Yeah Me! Thanks for the great pictures and info Jim.
C. Ledbetter, that would be great if you happen to have a manual. Thanks!
RE: Tartan Twin info
If anyone is interested in purchasing a Tartan Twin, I have one with the Ousley Modifications and reed unit for sale at a low price. Also have the Miller reduction starter. If interested PM me.
John
ORIGINAL: the Wasp
sooooo just what are these Modifications ???
LOL
LOL
