DA 50-R Igintion Kill Switch
KS
What kind of ignition kill switch do they have for the DA 50-R engine?
I'm interested in what people are using for the kill switch, besides the
electro Dynamics fiber optic kill switch. Also where to find one on the net.
HLC
HLC
DC
Another way is to glue a micro switch on top of a small servo, make the round wheel into a cam..run the ignition positive wire through the switch, use the landing gear switch on the transmitter to kill the engine...[8D]
![](/forum/images/badges/trading_plus_member.png)
My Feedback: (18)
ORIGINAL: kstinman
I'm interested in what people are using for the kill switch, besides the electro Dynamics fiber optic kill switch.
KS
I think they want too much for a kill switch.
I think I am going to use this switch and see how I like it.
I want to be able to turn it off and on at starting time, but guess I'll
have to remember to flip the radio switch when I get ready to start the engine.
http://www.rcatsystems.com/electronics.php
HLC
HLC
My Feedback: (18)
ORIGINAL: Goekeli
Got a link Galen? i was looking at the smart fly FO kill switch for my DA50.
Joe !~)
Joe !~)
My Feedback: (18)
I use the FO kill unit and closing the throttle to kill the engine in my Edge. Ideally I should mix these together on one switch, but I haven't... I like the idea of being able to kill the engine without having to rely on a servo. The solid state FO unit should never [
] fail as it has no moving parts...
![Embarrassment](https://www.rcuniverse.com/forum/images/smilies/redface.gif)
My Feedback: (18)
ORIGINAL: JohnVH
what do you do if your RX fails? what do you do if your elevator servo fails? Wingtube....ect.....
How many batteries and receivers in your new 40% model? Servo failure is another benefit of having more then one servo per control surface. If lost of the servos on you 40% aileron you would notice and land... If you have a structural failure then it's simply game over. However, you can take a few reasonable precautions -- like redundant receivers and batteries in larger models -- and FO kill switches on the engine.
You guys are free to put whatever you want in your models. As for my models -- I'll be putting at least a FO kill switch on my gassers... We'll see what happens if, and when, I join the 40% club...
My Feedback: (38)
Hi Galen, I have two RX's and one battery per RX in the 40%. I have flown and landed it on one RX=one elevator half, and one aileron. Flew fine that way, this was before it was mine. One battery died in flight.
The reason that you see multiple servo's on a surface is for more power, not more redundency. Oh, also, the reason there is two RX's is not redundancy, its to handle the power load of all the servo's. Both my 33% are on one RX. With the reliability of my servo's, its not a concern to me.
![](/forum/images/badges/premium_member.png)
Do you think a kill switch is necessary with it's added cost and complexity? Not really, you take the chance of any servo failing on a airplane. If a servo would have to fail, I would love to have it be the throttle. I can deal with that. What is the worse that can happen? So you fly around in circles until you run out of fuel, big deal. Did anyone think it was necessary on glow engines? Why is it any different with this one? Just a few questions to ponder.....
Dave
Dave
KS
I'm sorry I started this opinionated thread. To each his own.
Kill switches are recommended by AMA, but it is a choice for each person
to make for himself and I was just trying to find a good kill switch for my
own use, not start a debate.
I have found the switch I want so, to use or not to use is not relevant to me.
HLC
HLC
in spite of the 2 recommended switches you managed to find a third choice which may be unsuitable because of radio interference. that is the reason that smartfly and electrodynamics use fiber optic isolation. hence they cost more. i certainly agree with you that many people jumped in with answers to a question that you didnt ask.
I have read all the comments before and now again about the plus and minus. Strictly a choice of the individual.
My questions is that everyone says the battery may die before the fuel runs out. My question is depending on the initial condition of the battery, just flying around in circles shouldn't drain the batteries as quickly as flying since there would be very little servo movement to circle. I know digitals will draw a little more, but if you start with your batteries near full capacity, can't you circle for quite a long time?
Mark
Mark
