What would cause this symptom?
My Feedback: (22)
When I throttle down my gasser, the rpms stays kind of high, and then slowly settles down to a very low, dependable idle. It takes about 8-10 seconds. Throttle up transition is great, as is high end. Walbro 529 carb.
DC
Try leaning out the low end until the transition goes away, then open until it is just good...
Sounds like maybe you're using the low end to help the high...start with the high first open both about 2 turns, set the high, then the low...[8D]
