Zenoah G62 Smoke
![](/forum/images/badges/trading_plus_member.png)
My Feedback: (60)
UT
I just got me a g62 to put on a giant areomaster Bipe. I have a couple questions about getting this thing set up. #1... Where is the best place to inject the smoke oil on this engine? I did get a pitts style muffler for this but it only has the one nipple for gas tank pressure. My second question is about the gas oil mix. I've heard synthetic is the way to go but I'm open to whatever works good. What mix ratio do I need and what brands are recommended?? This is my first gasser so it should be fun.
![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
Hey Keyserman. Take care about nipple for gas tank pressure, in gas engines you don't use this. Gas engines literally spits fire by the scape, if you connetc it to the tank, you are creating a bomb! I have one Zenoah G62 and I put a nipple for smoke oil on the side turned to the firewall, little bit lower than the level of the exit from the cylinder (entrance of the muffler). In fact, the muffler will burn any oil inside, practically don't matter where you inject it, but give preference to install it near to the cylinder exit. Other tip, use a long nipple and metalic holders (Dubro stile) to keep tight the oil hose.
SC
There is no pressure used on a gas engine. The nipple is for smoke fluid. I use Amsoil at 80 to 100:1. Works great, breaks in easily, and runs clean.
Dr.1
Dr.1
My Feedback: (60)
UT
Hey, thanks for the quick come backs guys. It shows you what I know about gas engines, huh? I think the bomb thing might be a real show stopper at the field though![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
It was mentioned to use a long nipple or metal connector. Will neopreen hose hold up to the heat for the smoke? I'm also using tygon hose throughout the system for the gas. It seems kind of stiff. Is there a better choice? I've had to put hose clamps at every joint. Oh, the bomb thing brings up another question, since I now have the line that I was going to connect to the muffler to presserize the gas tank.....Do I need to plug it after filling the tank or does it just stay open as a vent? Thanks again.
My Feedback: (58)
VA
Hi Keyserman, You just vent that line out the bottom of your plane. I usaly put a loop back to the rear of the tank to keep gas from leaking when picking up plane. I tape the vent line to the top of the tank. Hope this dont confuse you and helps. You have to vent or you could not fuel the plane. Wayne M.
1. neopreen are excellent for the oil system.
2. get a 40cm capilar cupper wire 1/8 size diameter and warp it arround one of the pitts exh outlets and than connect an addtional neopreen to the nipple, this way you make sure that the oil gets hot before it inters the exh - it will burn better and youll get a butifull showstopper smoke!!!!!!!!![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
gadix
gadix
My Feedback: (60)
UT
Thanks for all the help. I have one other question for you zenoah guys. This engine is used and has a rather large nipple on the exhaust port side of the motor. It is located just below the split between the jug and the lower part of the engine if the jug were on the top side. I'm not sure if it is stock or not as I don't have the owners manual. What is it for?? If anyone has a clue let me know. Thanks
My Feedback: (84)
IA
The nipple below the exhaust port is for pulse preasure. It was most likely used to run a smoke pump like a B&B unit. If so it should be an extra large one, 1/4". It could be utilized for any thing requiring pulse drive though.
look here;
http://www.bennettbuilt.com/smoke.htm
to check out the B&B smoke system. I just did one. Haven't used it yet. I'm finishing up a Byron 28% Extra.
look here;
My Feedback: (60)
UT
The smoke pressure is the probable use as it is about a 1/4" nipple. I already have a TME smart smoker installed in the plane as I've had great luck with them on my four strokes. So I guess I'll just cap this off for now. Thanks loads.
![](/forum/images/badges/premium_member.png)
My Feedback: (51)
keyserman, can you take a digital photo of the pressure fitting location on the G62 and either post it or send it to my email addy? I have a G62 that I bought a few months back and am in the process of putting it on a plane now, I would also like to put smoke on it. I am looking into the Bennett smoke systems and need a 1/4" fitting and also need to know where to tap the engine to install it. Thanks, [email protected]
