Balancing a 1/4 scale size APC prop.
![](/forum/images/badges/premium_member.png)
I have an out of balance 17" prop that might need to have one of the blades shortened by about 1/8" inch to get it balanced laterally. Is this acceptable, having one blade that much shorter than the other.
![](/forum/images/badges/trading_plus_member.png)
CA
Do not shorten 1 blade. I use clear spray paint to balance horizontally first. Then I balance the hub vertically by adding wt. in the form of epoxy/microballons or a piece of velcro with ca.
SC
If it's an APC prop, and that far out of balance, take it back to where you bought it. Composite props should be almost 100% in balance by virtue of the material used and manufacturing process.
Dr.1
Dr.1
